Hi.
I just put all together and I have question about fuel pump.
I have outer bosh 044 pump.
Can I run pump by toogle switch?Or better go by stock wire lum and ecu?
Hi.
I've the same setup, I've mine wired to the battery through a relay on a switch that's only live when the ignition is on, everything works perfect
Thats great I try this setup and we see how this work.Thanks.
