not sure how i did it but i bent the small threaded bar on the hydro, can this be replaced by any threaded bar or will i have to replace the hydro?
The bar can be removed easy enough removed,
There's a circlip in the end of the cyl. that holds it in place,
It has a kind of ball on the end so just a peice of threaded bar won't do,
You could get one from a fucked cyl if you knew someone that has one...
Thanks for the replys. We had it fairly mounted in place id say it was just over tight maybe meaning extra force was used when pulling. Will try get a wilwood cyclinder as i dont fancy going all the way to cork and it snapping on the first bend, the joys of cars![]()
Keep out of the gym lads![]()
[SIGPIC][/SIGPIC]
