Results 1 to 10 of 15
Thread: bent hydro!!
    Mar 2013
    Default bent hydro!!
    not sure how i did it but i bent the small threaded bar on the hydro, can this be replaced by any threaded bar or will i have to replace the hydro?
    galway
    Exact same thing happened to me in tynagh the last day, bent the threaded barnand snapped it.
    You can buy replacement cylinders, a lot of people recommend buying a wilwood cylinder as they are supposedly betters, they are around 50 euro
    Loves S13s LarZ's Avatar
    Apr 2012
    Ballincollig, Co.Cork
    I'd say it's a mounting issue. the slightest bit of bend on that little bar will cause it to snap over time, especially if your hydro need a bit of leverage or force to lock up. I read about it before I got mine and ended up getting one with an OEM bracket to prevent the issue:
    di Member Foxyfenlon's Avatar
    Dec 2011
    Wexford
    The bar can be removed easy enough removed,
    There's a circlip in the end of the cyl. that holds it in place,
    It has a kind of ball on the end so just a peice of threaded bar won't do,
    You could get one from a fucked cyl if you knew someone that has one...
    Mar 2013
    Thanks for the replys. We had it fairly mounted in place id say it was just over tight maybe meaning extra force was used when pulling. Will try get a wilwood cyclinder as i dont fancy going all the way to cork and it snapping on the first bend, the joys of cars
    i love lamp cooks86's Avatar
    Feb 2011
    tipp
    Keep out of the gym lads
    [SIGPIC][/SIGPIC]
    Junior Member SullyMotors's Avatar
    Feb 2013
    Galway
    Ya have to much practice pulling yourself the poor hydro couldnt keep up..lol
    Its them chinese cylinders that keep bending.
    Have a group4 fabrications 1 in my own car and no problems.
    The chinese 1's i think 3 people bent that bar in tynagh the last day.
    SuperFortress
    Oct 2009
    Galway
    Quote Originally Posted by SullyMotors View Post
    As far as I know Nick was in with Group4 before he installed his hydro asking about plumbing it and they mentioned that were very certain that it was on of their own hydros ..... Who knows, so many possibilities
    Feb 2013
    Galway
    Ah yess he bent his the last day alright.
    He got fittings off me just before and dont think it was the same as the group4 cylinders.
    Could be wrong though was only a quick look.
    galway
    Sure I had a group 4 one and the bar on the cylinder ended up more bent than elton john :P
