Results 1 to 3 of 3
    di Member ali-d1936's Avatar
    Default ffs wipers not working now!! help?
    well i haven been haveing a ball of misfortune with the car the last few months. last time i knew the wipers where working was 2 months ago the car has been parked est then. last week i tucked the loom and .now i noticed the wipers will only work at the hightest speed setting and they will not return to the bottom of the window when you flick the leaver up it will just stop where ever you flick up the leaver. also the washer jets dont work either. i checked the 10amp fuse in the foot weel for the wipers. and its grand checked the brown and white block connectors behind the steering wheel that plug into the stalk. and they are fully in... i was very careful with the loom during the relocation..
    i pulled off the washer jet motor and crossed it off a battery and it fired up so its defanatly working.
    i thought myself it was a stalk problem as the wipers or the jets where not working but i changed the stalk today and there is no change in it.
    now iv been told there is a wiper amp solanoid in the car but i cannot find it its not in the engine bay as the rest of the s13 and s14's. any one know where it is?
    hellllllpppppp :/
    Member rps13Carlow's Avatar
    Sep 2012
    downtown nagasaki
    Unplug everything from wiper motor, abs unit and wiper control box and pull the loom through the passenger wing by the wheel and inspect all the wires there for fraying/damage where the loom passes through the wing. 15min job
    do you know where the wiper control box on a s15 is? been searching all ober the car for it )/
