Results 1 to 10 of 11
Thread: Bmw hydro?
    Mar 2013
    Default Bmw hydro?
    A local mechanic up the road is doing the hydro for our 5 series bmw. He says thats it is very compicated and has to go cutting the lines out of the chasis and get various bits, is it as complicated as he makes out as i need it for driffest on sunday! Thanks
    Nov 2010
    Some info here:
    driftireland.com/forum/showthread.php?t=24916
    driftireland.com/forum/showthread.php?t=27847
    di Member gary g's Avatar
    Dec 2009
    galway
    Quote Originally Posted by shtones View Post
    Parts needed: 1 roll of copper piping maybe small bit more depending if you have abs
    2 'T' pieces max, 1 might do again depending on if front brakes need to be replumed,
    Nice bit of brake fluid.
    A few brake fittings roughly around 11 get 15 to be sure
    A hydraulic cylinder size (.625) would suit best I find with a decent make I.e wilwood, girling.
    A hydraulic handbrake lever+mounting bracket.
    Process: old brake lines have to be removed and replaced with copper piping or braided line, one line ran from your master cylinder to the rear of your hydraulic cylinder, one line ran from front of your hydraulic cylinder to the rear wheels 'T' piece probably required for the rear. next would be to run more piping from master cylinder to front wheels unless you dont have abs and they have two pipes running there already, last but not least bleed fluid through the whole system and your done.
    Ive done a few hydraulic handbrakes in different cars.
    Mar 2013
    Thanks lads for the replies, hes humming and hawning about it hopefully i will show him this it will hurry him up as sunday is fast approaching! Could you drill a few holes and fed the copper piping that way instead of cutting into the casis to take out the exsiting lines as i want to keep original handbrake just incase?
    Dec 2009
    galway
    The lines shouldnt be in the chasis, there probably running along side it. You can easily keep your handbrake, I could do it for you if you like provided you have the handbrake and cylinder.
    Mar 2013
    only seen this now thanks gary for the offer but just booked her in with hugh o sullivan in glaregalway to do it as the man seems to know his stuff. hopefully will work as driffest sunday!. the previous mechanic told me that the 5 series needs a double master cylinder as single wont be as strong and could burst at anytime!!? i decided he didnt have a clue so took car back
    Dec 2009
    galway
    Thats no problem, best of luck with it
