Results 1 to 3 of 3
    Default 328i compact build ??
    what up guys ,
    after buying a 316i compact and just want to know what would i need to do for the build
    and also would woulds i have to do about the shafts ,diffs and prop ,
    have i bitten off more than i can chew ??
    di Member age's Avatar
    May 2012
    mallow. (cork)
    you'll need an engine from an e36,
    you'll probably need the ecu flashed to delete the ews ( for easy of fitting, plus you can get it mapped for an m50 manifold at the same time for a hp increase)
    you'll need the box and prop from the 328i
    diff i'm not too sure on, maybe an e30 one.
    and half shafts from an e30 are stronger so a good upgrade.
    it should be a bolt in job really
    sound job
