Results 1 to 8 of 8
    mayo
    Default sr20det engine problem
    Iv fully rebuilt an sr20det recently an car has covered 3000miles since was refitted.. in the last week the car wont take the shoe at all and will boost fully but no go in the car at all, iv checked all boost pipes and intercooler for leaks, tested fuel pressure, cas etc.. one thing i have noticed is car when is cold it revs up close to 1800rpm an after afew seconds drops back down to regular idle and when cruising at 60mph the car develops a slight misfire every now and again!! anyone have any ideas what it could be? timing issue etc?
    Member rps13Carlow's Avatar
    Sep 2012
    downtown nagasaki
    Injector seal leaking maybe
    its not low enough!
    Apr 2010
    galway
    Afm? Lambda?
    mayo
    have a new lamda sensor fitted and swapped afm with one of th lads cars an it runs the exact same.. Injectors are the only thing left that i havnt tried replacing yet incase it was something else
    Did you swap over the coilpacks at all?
    mayo
    Ya swapped coils an new plugs aswell there on wed but still no joy.. New fuel filter aswell cause it seems to have systoms of a car not getting enuf fuel!!.. Going to try swap injectors next week to see if there at fault!!
    MEATH
    PM pepsterx , bring him some coffee and a donut or 2 He won't see you wrong though. It could be one of many things
    mayo
    Il give him plenty of coffee an what ever else if he can help sort the problem out!!
