Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
  1. #11
    Cork
    Nice! Can't see why more people don't use the V8s in E30s over here!
    Any ideas yet on the brakes yet? You going to mount the servo again or go with a pedal box?
    Best method of using the pedal box or at least the neatest was using it up in the battery tray or else putting it in behind the glove box
  2. #12
    Mar 2013
    castlebar co mayo
    Quote Originally Posted by DaveM-sport View Post
    Cheers dave have been focusin mostly on the manifolds yet
    But thought I would go the pedal box routh but was thinking now I might be
    Able to mount the servo back wards behind the dash on the passengers side kinda
    Where its originally just on the inside facing inwards
  3. #13
    Cork
    Yea, a lot of people mount it in there but you mount it sideways rather than backwards. Actually works well as there's one less link to worry about so its just the linkage on the brake pedal and then te linkage bar that ones across behind heater motor acts on it directly.
    Pedal box is probably the most straight forward option though especially as its going to be a track car anyway.
  4. #14
    Mar 2013
    castlebar co mayo
    Ya ial have to look into it anyways have a cheap oul pedal box there for a mk2
    I wouldn't mind putting the grinder to see would it work
  5. #15
    Mar 2013
    castlebar co mayo
  6. #16
    Mar 2013
    castlebar co mayo
    well was busy this week got the engine mounts made up and the engine and box bolted in properly the mounts were handy enough to make up except the original passenger side mount the was in the 7 series hasthe main oil feed for the the engine goin true it which made things a little complecated.
    e30 v8 012.jpg that was the drivers side sorted any ways
  7. #17
    Mar 2013
    castlebar co mayo
    then the prick of a passenger mount i cut the leg off the old mount so all i had was the peace the bolted to the engine with the oil feed.
    Then cut 4mm off the back off the so it could over lap the mount i made and still keep the oil feed and original sealse30 v8 018.jpg
    it seem to be sealed with the block other than that they were very handy to do bar drilling hoiles with shit drill bits takes a fuckin life time but its done now anyways
  8. #18
    Mar 2013
    castlebar co mayo
    manifolds next as some of ye would now the drivers side manifolds have to be changed completly to get them around the steerin rack. probable no harm i had to do this as the old one was the most restrictive thing i ever seen
    does anyone know is there any real advantage to having the double wall on the exhaust its really annoying for working with
  9. #19
    Mar 2013
    castlebar co mayo
    put the wrong pics in there thats how they look now just have them tacked together there for now e30 v8 013.jpg
    e30 v8 014.jpg heres the original ones
  10. #20
    Dec 2009
    i woulndt burden youself with the double wall bm exhaust parts. every other exhaust in the world is single wall anyway. my guess is it was originally to muffle sound and heat and vibration when fitted in the 7. nothing to do with the running of the engine
