Its worth a try but if the exaust is blocked or restricted it would choke its self or not start.
The cas unit on the side has to be aligned correctly before its bolted up and as said get a timing strobe,
What fuel reg is it? If its adjustable and someone has messed with it?
Originally Posted by sc86
better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
No because whores like you will buy em and break em
Cheers for the comments lads, was talkin to a fella last night and he said its definatly ignition timing. The CAS is the problem, not adjusted correctly so im told. Im gonna have a go at it tomorrow evenin and see how i go.
When you set the timing, did you use the little black wire at the back of the engine or did you put a lead between coil pack and spark plug? My timing light went way off when I used the black wire method![]()
