Turn on ignition. And then turn on your wipers ir they moving at normal speeds then your battery is ok. Clicking noise could be bad battery connection.
And check wires on your starter. And also earth wire located somewhere on the side of your engine. My one snapped once, had same clicking noise and the car wouldn't start.
from what i can see im after doing something to the EWS anyone know how i can bypass it or disable it??
so got bord of doing nothing to the car so i took out the dash to sort all the wiring and made a panel for it..its gonna stay key start for now but that will all change later on down the line
