Results 1 to 4 of 4
Thread: engine mods
    Default engine mods
    Thinking of changing the turbo in my sil80 was thinking of getting a t28turbo any one got any suggestions on wheather it is a good idea or not!!! along with the turbo i was going getting a z32 AFM a set of 555cc injectors and a power fc ecu would i riely have to change all of this stuff to get the boost up and running propper???? i currently have a hks fuel pump and nismo adjustable fuel regulator installed!!!!!
    di Member thegosson's Avatar
    without that other stuff there would be no point in changing the turbo because they would all max out before you get the most out or the turbo. oh and get the t28r not just the t28 its the dual ball bearing one. tis mor modern and better power.
    imo theres no point upgrading your turbo unless your going to change your afm too dude. The standard afm is far to rescrictive to get the best out of any different turbo
    Like thegosson said, go with the t28r or if youve got the monies gt2871r
    the power fc is the handiest ecu to go with if you going to change afm and injectors, you can use the commander to alter the settings yourself. But as always you best to get her mapped to get the most of out it.
    Depends on your power goal at the min is too
    what ya aiming / looking for?
    - reliable relativly small up in power and get her running 100% -
    - or all this to prepare car for upgrades further down the line? -
