Results 1 to 10 of 329
Thread: justjap 180sx
    i measured the crank tonight with a micrometer, they measured 54.985-54.965mm i think it was. We had an undamaged crank there too and compaired them both and barts was actually measuring more consitant across all than the good one. It didnt spin any of the bearings.
    There is very slight scoring on the journals, you can see them on the surface but are very hard to feel under your fingernail, Not perfect but far from fucked. there was unbelievably little damage on them given the bearings were knackered
    Drive 'er on so
    @JH - No probs
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by colm View Post
    Did you measure the bore of the con-rods when torqued up ? Did you check the line bore of the bock ?
    Robbie
    di Member bart's Avatar
    laois
    Quote Originally Posted by robbie@tdp.ie View Post
    Robbie
    maybe colm could help on this one....
    Quote Originally Posted by bart View Post
    he means did you torque up the caps on the con rods and measure the inside of the hole if the rods were over heated or run for a period of time with the bearings gone the hole can be gone out of shape causing odd pressuers or loosenes in one or more spot on the crank causing bearing failure,
    and by the line bore i pruseme he ment that the bores (cylinders) are 100% in line and square to the crank journals if not the rod will be at a slight angle to the crank and wear one side of the bearing
    Your 50% right Gem.. The con rods go oval form the pounding and heat. If there not re honed they will cause instant bearing failure again. The line bore is the main bearing caps and straightness through them.
    Robbie
