Results 1 to 10 of 10
Thread: bleeding hyrdo
    its not low enough!
    Apr 2010
    galway
    Default bleeding hyrdo
    quick one lads, changed rear subframe an rear pads, had calipers off so had to bleed brakes, bled foot brake as normal, but now i dont have much of a pull on the hyrdo, like its pulling the whole way back, is there a certain way to bleed with a hydro? cheers lads!
    Dec 2010
    just bleed front and rear as normal and run in the pads. then see what its like. repeat bleeding again if still not right.
    di Member kenny046's Avatar
    Oct 2009
    Quote Originally Posted by alan opel View Post
    having the same bother sometimes i have to give the brakes a quick pump to get pressure in the handbrake cylinder
    its not low enough!
    Apr 2010
    galway
    even to pull the hyrdo now its totaly different to what it was, it only pulled back a small bit before, goin way back now, ill give it another go the next day
    di Member Darenm's Avatar
    Sep 2010
    while bleeding front get some one to pull hydro back and them pump breaks while slowly leaving the hydro out should make a difference thats the way i did mine and it was perfect after changing pads
    di Member pinny's Avatar
    Mar 2011
    Galway
    Bleed as normal
    Once you have a good foot pedal then go to hydro.
    Pump up pedal, hold, crack nipple, pedal to floor, pull and hold hydro, close nipple, release hydro slowly, release pedal and go again.
    This has never failed to work for me anyway.
    You Only Live Once
    Quote Originally Posted by pinny View Post
    Bleed as normal
    Same way we do it aswell, can take fucking ages alan, just keep at it
    its not low enough!
    Apr 2010
    galway
    so press brake then open nipple then pull hydro? or press brake pull hydro and then release nipple?
    The way we do it is get foot peddle perfect.
    Then redo the whole lot again this time pump peddle as before then pull hydro back (last pump of peddle pull hydro at same time) Then with peddle down and hydro pulled back crack the nipple and repeat as needed. There is a difference i personally think between engine running and not.
    Sep 2010
    Pritty much as stevo said
    what i always do get peddle perfect then pull hydro open nipple and pump close and repeat may need to do it a few times always worked for me any way
