Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Senior Member ste's Avatar
    north dublin
    Default Spark plugs jammed
    Lads any tips on how to loosen em up, they are practically welded in and I broke a plug in a head years an years ago and don't fancy it happening again so I'm afraid to put them under too much pressure
    bit of wd40 down in the hole..never heard of anyone breaking them before..get a power bar if there that tight or air gun never had to do it tho.
    Cork, Ireland
    Find someone with less girly arms
    TEAM MANFOOT
    north dublin
    Quote Originally Posted by Chuck_g View Post
    The last time i got all popeye on plugs I snapped one and cost me a fortune so I won't be gettin all rough with em :-)
    di Member thegosson's Avatar
    Did ya try it with the engine good and hot?
    di Member doug's Avatar
    Feb 2011
    clare
    one thing id always be afraid of is braking a plug in the head,. what needed to be done to remove them?
    as said try with the engine nice and hot and wd40 ,
    spray the wd40 in first start the car leave it soak. whiles its nice an warm give it another spray and see then!
    Quote Originally Posted by ste View Post
    Lollerskates
    north dublin
    Quote Originally Posted by doug View Post
    I was told the head was stripped and plug removed from the other side, head skimmed new head gasket too... Happened to me on a fabia
    di Member podgedun's Avatar
    May 2010
    Carlow
    just pull the bar evenly, don be jerkin.. a continuous pull is the trick in not breakin things
    Someone that is used to that sort of work like Gem say would know if the plug is going to break.
    So my advice would be don't panic and let someone like that loosen them.
    Often lads don't know what they are at break stuff be being rough and jerking ratchets etc.... Not saying that's you Ste
