The minute the car comes on load starts breaking down and spluttering
Changed the plugs and slightly better but still in it
Anyone ever come across this
Try the usual suspects, fuel pump, coilpack, coilpack loom, ignitor ect ect ect
Will it drop a cylinder when its idling? Sounds like a coilpack to make sure find what cylinder is missing, just unplug one injector at a time, as you unplug a working coilpack the miss will worsen as the car is now only fireing on 2 cylinders, when you unplug the non working there will be no diffrence, change the suspected faulty coilpack with Another coilpack on the engine, if the missfire changes to the other cylinder then its your coilpack.
I have a similar issue with mine was told its the early signs of a coilpack going, but my earths where a bit shitty too so i cleaned them up and sofar so good.
And stevo thats a scary looking signature!
Cheers lads it idles fine and drives fine up to 3500 rpm minute you plant the shoe then just starts spluttering and holding back
