Last ad was a bit crap so said i'd throw up a list of the bits i have.
-Bride s-body low rail drivers side €100 or swap for bride passenger side rail
-180sx L&R headlights (94)
-Ps13 front & rear calipers/discs & 4stud hubs
-S14 Brake calipers F&R /discs Fr x6 Rear x6
-PS/180sx wishbones front x4
-180sx & S14 standard rear arms & front tension rods
-SR20det Standard manifolds x2 & elbows x2
-180sx fuel cap cover
-200sx S14 UK ECU
-s14 JAP ECU
-180sx redtop & blacktop ECU'S
-SR20(DE) engine/loom & ECU 75klms MINT
-SR20 starters-alternators-p/s pumps-Flywheels and 2nd hand clutches (std)
-180sx (94) clocks (114klms)
-S14 96 dials x2
-S14 zenki RH headlight
-s14 wing mirrors black
-S14a 99 engine mounts
-C-West sideskirts off 96 s14black
-S14 front shocks x6 rear x4 all with lowering springs
-T28 turbos x2 both smokey 1 not very bad at all
-Brake & Clutch master cylinders 180sx/S14
-S14 Afm X2
-blitz/k+n/HKS/Apexi airfilters
-180sx rear TANABE strutbrace
-R33 full rear subframe-front hubs with upper and lower arms
-R33 tail light RH and panel between tail lights
-indicator & wiper stalks from 180/r33/s14
-Sr20 coilpacks x16
-(95)S14 UK taillights
-s14 front grille 96
-Sr20 gearbox fucked
-2x 180sx doors/glass and regs
-s14 and 180sx doorcards
-R33 LH door complete also rear bumper
-S14 RH door
-180sx windscreen perfect condition
-180sx boot lid with glass
-S14a bumper (no splitter)
-99 S14 welded diff i think this was a 1.5way before sum idiot welded it
-RB25 radiator & SR20 radiator
-180 font subframe
-s14 half shafts
Good few bits there, I also have an SR20 VVT engine with the rod out of the block and plenty engine internals for sr's vvt cams etc etc.. and an rb25 engine split piston 5and6 are chewed up!
I WONT GET INSULTED SO OFFERS ON EVERYTHING , BUT THEY WILL BE CHEAP AS I NEED THE MONEY AND SPACE WOULD HELP ALSO
Pm, Txt or Call me for further info on anything.. (087) 7476981 Thanks for looking .
