rite put a non vvti 1jz into my altezza engine was perfect before the swap running fine after the swap had a few problem had a missfire but found the loom to be the fault so swapped it out with another one i had problem solved
but theres another problem when the car is cold i can full throtle it as it warms up if i give it more than 25% it bogs and splutters and bangs swap all the sensors and changed one of the turbos tryed swapping around all the vac pipes but still the same its a real pain in the whole at this stage
standard engine with straight threw 2.5 s/s exhaust and front mount
can anyone shed any light on this i tought it might be a wastgate sticking open as the car will only boost to .5 even when cold so only one turbo is working i think i cant find any boost leaks at all and engine is just rebuilt but had the same problem before rebuild
any help would be grate beers in it for whoever can tell me what it is
