Results 1 to 10 of 17
Thread: rx7 engine
    Mar 2012
    galway/cork
    Default rx7 engine
    hello all i new enough here well new posting here anyhow. i just bought an rx 7 with no engine. was thinking of sr20 has anyone any input. i know james dean has it done an it is savage. any help would be really apprecated. anythin from engine fitting to mods to extra lock. hopin to have it ready for next year season
    SM Vehicle Services driftfan's Avatar
    Ballymoney
    Ken Keightley done it a while back think his name on here is Ken Red 180, heres the link to his project thread; http://www.driftireland.com/forum/sh...ad.php?t=22316
    Mar 2012
    galway/cork
    savage thanks thar is a really good start. he fairly sank the engine back into the firewall. any other help or links or help would be really apprecated....
    Team Chihuahua Kruizer's Avatar
    Limerick
    Hey fella, did the same myself, both a 7 with no engine, you can pretty much fit anything. You can bolt in kits with wiring harnessess from Tech2Motorsport for the 1JZ and 2JZ engine. SR20 is probably the easiest option, you can also go the 1UZFE engine, RB25 / 26 etc... Really down to your budget
    Mar 2012
    galway/cork
    Quote Originally Posted by Kruizer View Post
    wha advise you got for me. i was onto you before was goin puttin in a evo engine but decided aginst it!! is there much fabrication???? did it take you long?? was the lum an issue have you any picks of fin product.
    i like cake
    not shure but off the bat i could say bell housing, wiring, engine mounts, prop the list goes on wood be an awsome strong engine though!
    Mar 2012
    galway/cork
    Quote Originally Posted by decobyrne106 View Post
    well bell housing an gearbow no bother they matchin up as they are. not sure bout lum an il have to fabricate a prop, i just worried bout the frunt subframe an stearin rack. one thing for sure is. it will be done an ready for next season keep info coming thanks
    Limerick
    Engine and Gearbox mounts will run you between 600 to 700 as the sump on the SR20 interfere's with the steering rack. Prop is 225 - 250 max, you just need the prop from the car (RX7) and the front half off the SR box. Wiring can run anywhere from 500 (basic) to 1000 depending on what you want done, wire tucks etc drive it up. Sorting the steering rack issue is another 100 squids roughly. Then you have all the other bits to think of, ecu nistune : 650, intercooler 200, piping & mounting 250 - 300, alloy rad 150 and mounting 50 - 100, fuel pump 100 and finally exhaust system as the rotary system is on the wrong side 300. Around 3k in total...
    Optional Extra's for more power then are obviously things like injectors, a/m turbo, manifold, exhaust system, z32 afm etc
    Mar 2012
    galway/cork
    nice one thanks il be on to ya soon ha ha ha
    Member A.O'Neill's Avatar
    Oct 2011
    cork like
    Why don't you just put a rotary back into it!!youd be supprised how much abuse they'll take once you look after them!
