changed the engine recently in my r33, since i changed it it revs up and down when ideling for maybe 20seconds and then goes back to normal, it revs between 1200 down to 200rpm. it only does it sometimes. can anyone shed some light on this for me??
spec 1 or 2 ? tiny vacuum under the trottle body forgotton maybe
sorry forgot to mention spec 1
If it was a straight forward swap i'd check all vacuums and intake pipes etc, then go over connectors and tighten the pins (electrical connectors) .
Dodgy MAF or Lambda
Is it hard to start ? have to hit th trottle to get it to start/idle?
Iv a RB20, its a bit hard to start & when it does it wont idle till you give it a little rev and its grand then... Only starting is my issue, it idles a little low but i cant find anything yet... iv found a few vacume leeks but thats all!!
Check the vacume underneeth the firewall on the drivers side, small little black box has a vacume going into it (on a R32 only)
Does sound like the vacumn pipe on the throttle body, they tend to crack
