Results 1 to 7 of 7
    Administrator
    Ennis
    Default Are rb25de and rb25det engine looms interchangeable?
    Hi all,
    I've recently picked up an r32 gts2.5 4door na auto.
    I bought as a semi rolling shell, but still had the engine loom attached.
    Im just wondering if i decide to go rb25det, would the loom match up? Im referring to spec 1 as i know alot changed for spec 2. I dont mind having to rewire, but would be so much easier!
    Andrew
    www.stickybusiness.ie
    Vehicle Graphics & Signwriting
    Administrator
    Ennis
    bump!
    The loom in the 4door r32 rb20de was the exact same as an rb20det
    Senior Member grange's Avatar
    galway
    hows it looking now andrew?
    team ball bag
    Administrator
    Ennis
    i have it down to bare metal. everything removed. 50% through sound deadening removal. gathering bits slowly. hope to sandblast the rear subframe, treat it, paint it and start reassembly by next week some stage.
    I have a S1 RB25DET engine loom if you get stuck Andrew.
    http://r32life.blogspot.com/
