Results 1 to 7 of 7
    Jun 2011
    Default e36 extra lock please
    Wel lads lookin ta find out how much i need to cut off the knuckle, what to add on to the wish bone and how much do i need to move the rack on a e36 bmw ta get good lock?? Any help much appreciated!!
    May 2011
    castlefin co.donegal
    20mm off the knuckle 30mm into wishbone no
    Need to move rack jus space the inner tie rod 6mm
    Use a spacer or some €2 coins with the center knocked
    Out
    di Member conor's Avatar
    Castlebar co.Mayo
    m3con has it all said here really
    if you dont want welding e46 wishbones fit and are an inch longer than e36
    Sep 2010
    kerry
    the 2 boys have it covered for you really...off topic.is there any point fitting extended arms and rack spacers if you dont have the knuckles cut? have the arms made longer but havnt done the knucles yet.any point fitting them till the knuckles are ready?
    Jun 2011
    Cheers lads!!
    Cork
    Quote Originally Posted by dermot-r32 View Post
    Not really as one of the main reasons you extend the wishbones is to move the wheels away from the chassis legs to stop them catching when you've the hubs modified.
    You'll also need 20-25mm spacers with most wheels too even after extending the wishbones. I've E34 M5 wheels which are ET20, wishbones extended 35mm and 25mm spacers and the R888s still are only barely clearing the chassis legs at full lock.
    Jun 2011
    Cheers lads, what did ye use ta weld dem, da wish bone seems like cast or forged..
