Results 1 to 10 of 15
    Ennis
    Got her into the garage over the weekend and managed to start the ripping this evening.
    Front subframe and suspension off:
    www.stickybusiness.ie
    Vehicle Graphics & Signwriting
    Ennis
    Jesus....
    6 months since an update? and doesnt look much different. although the garage corner isnt so tidy these days.
    So far i've the following bought:
    Engine:
    RB25DET Spec 1
    SARD FPR
    Front mount intercooler
    Toyo Oil Cooler with Relocation
    55mm Alloy Rad
    GTR Fuel Pump
    3in stainless downpipe
    Front Suspension:
    R33 Subframe
    R33 P/S Pump, rack, etc
    R33 Tie Rods & Ends
    Driftworks Camber Arms
    Driftworks Tension Arms
    Driftworks Lower Arms
    MDU Coilovers
    5 Stud Conversion
    R32 GTR front brake setup
    Completely polybushed
    Driftworks braided clutch, hydro and brake lines
    Rear Suspension:
    Non Hicas Subframe
    Driftworks Solid Subframe Bushes
    Adjustable Camber Arms
    Adjustable Caster Arms
    Adjustable Toe Arms
    5 Stud Conversion
    MDU Coilovers
    R32 GTR Rear Brakes
    Hydraulic Handbrake
    Driftworks braided hydro and brake lines
    Electrics/Gadgets/etc:
    Twin 12in elec fans
    HKS EVC Boost Controller
    HKS 52mm water temp gauge
    HKS 60mm boost gauge
    Loads of toggle switches, cut off switch, etc
    Z32 ECU
    Z32 AFM
    Interior, etc:
    Manual pedalbox conversion
    Dished steering wheel, snap off kit and boss kit
    Exterior:
    Full Vertex Kit
    Fibreglass Bonnet
    How it was sitting before fitting coilovers (sitting on bilstein suspension)
    I hope to get alot more done next week while on holidays
    Aug 2010
    ya need to get this sorted and get driftin
    Senior Member grange's Avatar
    haha ye the back of the van was full with everything to finish this the last time we met
    team ball bag
    Member Johnnyghia's Avatar
    Aug 2011
    North & South Dublin
    Any updates Andrew.
    who did you get your twin fans of andrew?
    team ball bag
    Ennis
    ebays finest! about £50 for the pair + postage i think
    you'll get twin 12s on an r32 alloy rad no problem. have it set up same on my road car
    Ennis
    not a whole pile unfortunately.
    waiting on a pallet of parts to arrive from the uk.
    have started piecing together the interior (interior fans) and going to start tackling the dash wiring over the weekend hopefully
