Results 1 to 3 of 3
    Junior Member Ciano's Avatar
    Aug 2012
    Default Changing ignition barrel
    Iv a steering column there with the ignition barrel attached to it and Im looking to put the barrel into my yoke. Theres two bolts holding it onto the column but theyve domed heads, Whats the best way to remove them? I was going to use a hammer and a small chisel to tap them around but wud be a butcher job tightening them back on so anyone know the right way to go about it??
    Mar 2011
    Fermoy
    I cut a line in each bolt and used a screw driver to take them
    Out
    Aug 2012
    A1, wasnt sure if theyd be loose enough for a screw driver but thatll do, cheers lad
