Results 1 to 5 of 5
    Default Help please!! Is a R33 front subframe the same as a R32 subframe
    need to replace this in the car, chap only up the road has a 33 one but couldnt be sure if they are the same if anyone can help and thanks in advance
    di Member pepsterx's Avatar
    Mayo
    Quote Originally Posted by B&G Extreme Drifting View Post
    I think if the 2 cars are running the same engines IE RB25 i think they are the same if 1 is 20 and the other 25 i think you'll need engine mounds and brackets, hope this helps
    Quote Originally Posted by pepsterx View Post
    I have rb25 in the r32, but the subframe is a 32. silvertooth only up the road has 33 jus wanted make sure the steering rack and wishbones and all that lark are the same, as in the subframes are same width?? but if there is small difference in lenght im sure it could be solved by adjusting them out...
    just dont wanna be making work for myself
    thanks man
    Mayo
    thanks man
    Rory would know 100% any way dude, just give him a shout ha
    MEATH
    99 per cent sure that once correct mounts are used with correct subframe they can be swapped about- just done my 34 today and I'd swear its a 32 subframe and same mounts as rb20??
