Results 1 to 10 of 10
    Default Viscous v Electric Fan
    Out in Mondello yesterday saw alot of lads having trouble keeping engine temps down due to out one day of summer!
    Put me wondering whats the mose efficent for cooling?
    Viscous Fan with cowling
    or
    Twin electric fans on a switch
    Any of ye have before and after experiences with them with actual temp readings?
    Cork
    Why not both?
    Iv been told Viscous is better than electric fans.... I use Twin Electric Fans on the skyline and no problem.. Only because i cannot fit a Viscous fan in
    From sxoc the lads there seem to say better cooling if you keep the cowling anyway.
    Seems to be more air directed from the rad towards the rad with the cowling in my experience too. Seans car has the cowling and mine only had a fan on the rad and theres way more air being pulled on Seans car than there was on mine. Id keep the cowling on any car I have in future anyway
    Pro Driver
    Viscous is the best option,
    Quote Originally Posted by PeterT View Post
    Incase you havnt noticed, this is driftireland! Not youraveragelookingcountryspeccivic,needsweelsandle sstackyshit.com!*
    That what I have On mine buddy, never wounce Over heat also
    Have a Ali rad too, done few drift days and the across Europe as ya know
    Only problm I had was that battery in millian lol
    It be grand they said, keep her lit they said ........ Lol
    Ah yea Ive the cowling and Greddy rad and oil cooler.. Was running perfect all day even in the savage heat just seen alot of yokes running without bonnets and stuff so just wondering..
    If I did have issues would probably look at running a twin setup alright Dave..
    Need to get a few gauges alright though to see whats going on with temps anyway
    Viscous and cowling all day long.
    Things that can go wrong with a electric set up:
    1.water temp sensor can go faulty
    2.relay can go faulty
    3.fan fuse can pop
    4.fans can burn out
    You wouldn't know any of these had happened if you were driving,the viscous runs all the time grand it doesn't look the nicest but it does the job and provides better cooling than most electric fans
    Quote Originally Posted by tweek View Post
    3.fan fuse can pop
    4.fans can burn out
    this is exactly it and usually too late when you find out.......kepp the visscous and cowling and use a good coolant, on my old car i put a electris fan on the front of my rad blowing air in rather than sucking into the engine was blowing through the cowling along with the viscous found it great
    cork
    ^^yeah a vicious fan is great,especially when running full belt.only thing is not great at idle so push fans aswell is the best thing
