Results 1 to 8 of 8
    Jul 2012
    Midleton, Co. Cork
    Default Hicas removal s13
    Hi all, new to all this but was wonder did anyone remove their hicas from a s13 180sx. I have super hicas, I went about an eliminator kit but was told that to replace the subframe would be alot more effective for drifting and a cheaper option. What would be involved in changing or how would i go about it and what comes with a stardard subframe if i was looking for 1 second hand. eg. Hubs, wishbone etc
    Any help would be appreciated
    its not low enough!
    Apr 2010
    galway
    the camber arms, hubs, etc are the same, youll need a bare 180 subframe, two bushs, you can get poly ones for about a 5 each! pair of rear toe arms and the ecccentric bolts an nuts for them, u dont need a full subframe ! better off buying a 180 p/s pump too, an pull the lines out the whole way to the front, instead of looping them b a tidier job!
    Jul 2012
    Midleton, Co. Cork
    Thanks alan. I get what your saying with the hoses but y do i need to change the ps pump. Im not that clued into it. And is it just a standard pump ill b looking for. Thanks kev
    its not low enough!
    Apr 2010
    galway
    Quote Originally Posted by Sil80 kev View Post
    ya! hicas pumps have extra fittings as the power steering fluid is pumped to the back for the rear rack! if u just get a std pump u can pull it all out!
    Team Nocturnal batman026's Avatar
    Corcaigh
    I have standard s13 rear subframe. with all standard arms here €80 0871893010
    Follow us on Facebook, CLICK the picture and LIKE please.
    <a href="https://www.facebook.com/pages/Team-Nocturnal/245958445511099?ref=tn_tnmn"><img src="http://i49.tinypic.com/bhktvp.jpg"></a>
    Jul 2012
    Midleton, Co. Cork
    Thanks alan. Great help
    Ive a proper hicas lockout bar there
