Results 1 to 4 of 4
Thread: e36 missing
    Apr 2011
    Kerry
    Default e36 missing
    I fitted the coilovers today and I was taking it for a spirited run home, was in high revs in 4th and going for 5th but put in third instead,
    There is a small bit of a miss now out of it when ticking over, it doesn't seem down in power tho which I find quiet strange,
    There was a small blow in the exaust before this any way, so I was thinking maybe this got bigger or something because it kind of sounds like that too,
    I'm just afraid I'm after doin damage to it now
    Cork
    Did it over-rev when you went to third?
    Could be after bending valves due to valve bounce especially when the engine has HVAs which don't work that well at very high rpm.
    Could be just a coincidence too though and maybe you've a fouled plug or bad coil.
    Coil problems and even any sort of missing should reduce power even slightly.
    Only other thing I could think of is the vanos could be after slipping timing a few degrees
    Apr 2011
    Kerry
    Ya it over reved alrite, I hope its nothing serious,
    I started it a while after and it was still at it, I took it for a small spin then and it seemed to rev like it was before after it, I'll have a better look at it tomorrow, and I'll give you a ring if its still at it to trouble shoot it to find out what's wrong with it,
    Apr 2011
    Kerry
    I started it yesterday and it was missing a small bit, I took it for a spin and it didn't seem down on power or anything, when I stopped then the missing had stopped it seemed grand then for the rest of the day, I'll check it again later now and hopefully it will be alright,
