Results 1 to 10 of 22
    Default SR20DET and SR20DE differences
    Lads have the turbo and non-turbo SR's have different internal's?
    Can i just bolt on all the turbo parts / wiring onto a SR20DE engine?
    Thanks in advance
    the de will have higher compression ratio and prob diff pistons and rods, ive not taken one apart so only assuming becuase of the different loads put on each engine
    the blocks are the same afaik though
    Pro Driver
    different block inside and the rods are way smaller and different pistons!!! smaller valves in the head!! it would blow in no time!!
    As said the internals are different,There is also no take offs on the DE block for the oil and coolant lines to the turbo.
    www.inoc.ie
    Irish Nissan Owners Club
    on sr20de:
    high comp pistons
    no turbo oil/water feed
    no oil squirters to the bottom of the piston (for cooling them)
    different injectors
    I presume valvetrain is different (esp. cams)
    clutch/flywheel are smaller
    plus some extra bits needed:
    CAS
    turbo AFM
    ignition amplifier (ignitor chip/module)
    loom
    prob. downpipe/elbow
    etc.
    Thanks lads, that puts dat idea outa me head. Thought as much
