cousin reshell'd the e30, everything wired up right, but the fuel pump and coil wont start when she turns over, everything is the same except the ignition is different, anyone know whats wrong???
Mick
Mick
youll need the same ingition in the car
thanks ill try it tomorrow!!
unless you have an e36 engine with ews in it you dont need the same key. if the pump isnt working and theres no spark youre not getting a crank signal, would you have another crank sensor to swap into it?
try the relays located on the bulk head
try them relays mentioned above, should have two there and the brown one is the one for the pump at least, dont remember bout if it controls the spark as well- short circuit it and see if pump starts working, there was no OBC removed of the car was it?
