1995 JAP IMPORT S14 SILVIA
BODYWORK
• Full uras bodykit with S14a front
• 30mm wide fiberglass quater panels
• 25mm wide genuine Chargespeed vented fiberglass wings
• Genuine Ganador mirrors
• New Carbon vented bonnet
• Cookie spoiler (painted but never fitted)
• Full respray
SUSPENSION AND DRIVETRAIN
• Cusco front and rear adjustable strutbraces
• Cusco fully adjustable coilovers
• Cusco adjustable top mounts
• Cusco adjustable front and rear arms
• Cusco 2way diff (redline gear and diff oils)
• OS Giken twin plate clutch
• New clutch cylinder
• Nismo engine mounts
• 18” ROTA torque 10” all round (new tyres)
• 25mm Ultralite spacers on rear, 15mm front
ENGINE
• Fully rebuilt S13 engine with receipts for 90% of the parts, all new gaskets and seals
• Bored out with CP Racing forged pistons
• Eagle con rods
• Arp main bolts
• Arp rod bolts
• Arp head studs
• Acl main, trust and big end bearings
• 264 Tomie cams
• Tomie adjustable cam gears
• New chain
• New oil pump
• New water pump
• New crank
• Block bored and decked
• Baffled Sump
• Gas flowed head
• 1.5mm Cosworth Gasket
• HKS valve springs, retainers and new valves
• Splitfire coilpacks
• 850cc Sard injectors
• New 255lt Walbro fuel pump
• New GT3071r turbo with HKS actuator
• Braided turbo and water lines
• Apexi filter
• New alloy rad
• New Apex front mount intercooler
• HKS manifold
• New Japspeed turbo elbow, downpipe and de-cat
• New 3” Skunk cat back system
• Engine damper
• Oil catch tank
• New battery
• Full OMEX 710 series ecu (no air flow metre), omex air temp sensor,omex front pulley with pick up sensor, full custom engine loom
INTERIOR
• R33 GTR front seats (back seats included but not in car)
• Fully professionaly flocked dash with built in guages in passanger side
• White dials
• Bride steering wheel and boss kit
• G-reddy profec-1 boost controller with display and remote inside car
• Kenwood headunit with built in g-force reader
• 6 guages- 2 bar boost guage,oil temp,oil pressure,vacume,water temp,exhaust temp
Also included:
Front brake calipers off an R33 GTST Skyline with brand new pads in the box
One brand new set of H7 8000k HID kit still in the box (never opened)
A brand new GPS tracker system still in box never opened (allows you to real time track the car via mobile phone or computer, can track to with-in 5 meters, allows you to cut fuel and or power to the car via your mobile or computer, hard wired in to car but has a 3 day back-up battery)
http://www.pistonheads.com/sales/4056375.htm[/URL]
