Results 1 to 5 of 5
Thread: big spec s14a
    di Member bart's Avatar
    laois
    Default big spec s14a
    1995 JAP IMPORT S14 SILVIA
    BODYWORK
    • Full uras bodykit with S14a front
    • 30mm wide fiberglass quater panels
    • 25mm wide genuine Chargespeed vented fiberglass wings
    • Genuine Ganador mirrors
    • New Carbon vented bonnet
    • Cookie spoiler (painted but never fitted)
    • Full respray
    SUSPENSION AND DRIVETRAIN
    • Cusco front and rear adjustable strutbraces
    • Cusco fully adjustable coilovers
    • Cusco adjustable top mounts
    • Cusco adjustable front and rear arms
    • Cusco 2way diff (redline gear and diff oils)
    • OS Giken twin plate clutch
    • New clutch cylinder
    • Nismo engine mounts
    • 18” ROTA torque 10” all round (new tyres)
    • 25mm Ultralite spacers on rear, 15mm front
    ENGINE
    • Fully rebuilt S13 engine with receipts for 90% of the parts, all new gaskets and seals
    • Bored out with CP Racing forged pistons
    • Eagle con rods
    • Arp main bolts
    • Arp rod bolts
    • Arp head studs
    • Acl main, trust and big end bearings
    • 264 Tomie cams
    • Tomie adjustable cam gears
    • New chain
    • New oil pump
    • New water pump
    • New crank
    • Block bored and decked
    • Baffled Sump
    • Gas flowed head
    • 1.5mm Cosworth Gasket
    • HKS valve springs, retainers and new valves
    • Splitfire coilpacks
    • 850cc Sard injectors
    • New 255lt Walbro fuel pump
    • New GT3071r turbo with HKS actuator
    • Braided turbo and water lines
    • Apexi filter
    • New alloy rad
    • New Apex front mount intercooler
    • HKS manifold
    • New Japspeed turbo elbow, downpipe and de-cat
    • New 3” Skunk cat back system
    • Engine damper
    • Oil catch tank
    • New battery
    • Full OMEX 710 series ecu (no air flow metre), omex air temp sensor,omex front pulley with pick up sensor, full custom engine loom
    INTERIOR
    • R33 GTR front seats (back seats included but not in car)
    • Fully professionaly flocked dash with built in guages in passanger side
    • White dials
    • Bride steering wheel and boss kit
    • G-reddy profec-1 boost controller with display and remote inside car
    • Kenwood headunit with built in g-force reader
    • 6 guages- 2 bar boost guage,oil temp,oil pressure,vacume,water temp,exhaust temp
    Also included:
    Front brake calipers off an R33 GTST Skyline with brand new pads in the box
    One brand new set of H7 8000k HID kit still in the box (never opened)
    A brand new GPS tracker system still in box never opened (allows you to real time track the car via mobile phone or computer, can track to with-in 5 meters, allows you to cut fuel and or power to the car via your mobile or computer, hard wired in to car but has a 3 day back-up battery)
    http://www.pistonheads.com/sales/4056375.htm[/URL]
