Results 1 to 10 of 10
Thread: Ek4 Civic
    May 2011
    Default Ek4 Civic
    Old spec
    Spec;
    b18c engine
    rc 330 injectors
    buddyclub light weight pullies
    spec 4 bc cams
    omi valves retainers springs
    ctr pistons 12.5 comp
    bc high comp headgasket kit
    bc racing rad light weight
    bc manifold decat
    itg maxagon air box
    New spec
    B18c4 bottom end
    Type r head
    Arp headstuds
    410 injectors
    Hks fmic
    T28 journal bearing turbo
    Hks adjustable actuator
    Apexi air filter
    Cast iron mini fold with custom made 3" elbow & down pipe
    s80 box wit final drive
    rps 6 puk clutch
    buddyclub spec 4 exhaust
    Neptune ecu launch control & shift light
    Ultralites alloys wit toyos
    6pot Ksports
    282mm EBC grooved and dimpled disks
    Cusco springs
    tyre r interior
    sparco snap of steering wheel
    Fully alarmed
    Future plans
    Get some fogs
    Remap with vtec6000
    Get some stuff carbon dipped (I think the car is just too white)
    Maybe a different lip
    Any ideas welcome
    May 2011
    Default April 17th
    This was when the old engine was in it
    Right i went down to Couture Auto today to get the car mapped by vtec6000 (sound lad to deal with)
    Turned out the map that was on the car wasn't the best to suit it the timing was off, there was detention happening and a few other things.
    Also the thermostat isn't working, the air intake has a crack in it and the cams need to be re-dialled and should get a bit more power out of the car aswell as a bit more torque, any ways im happy enough of the cars performance considering what needs to be done, the main thing i wanted is to hold the power higher in the revs and a smoother power band, which is a understatement of what vtec6000 done, the car is so smooth going up through the revs and doesn't die off higher in the revs at all instead it increases now and pulls harder through the whole gear,
    After i got the mapping done i took a nice spin over to Joe in Custom Metal Works to pick up the new disks(at a great price)
    May 2011
    Default April 19th
    Tried fitting the ksports to see if they will fit, what yous think?
    Sorry for the dirt
    its fairly tight, only think now is the bolts now are too short because of the ksport adapters, anybody know where i can get bigger bolts??
    May 2011
    Default May 6th
    Sent the car up to get washed by johno (professional valeter with savage savings, in the Dublin area anybody interested please don't hesitate to contact me and I'll put yous in touch) and was a fantastic job, I wouldn't let anybody else touch the car, the car was so dirty before hand it looked like a total different car after he finished it here are some pics
    What yous think?
    May 2011
    Default June 18th
    Right as some of you guys know the engine went and gave up on me on the way down to mondello on the bank holiday Monday,
    So I was left with 2 options either rebuild my bottom end or get a new engine, so I went for the 2nd option got in contact with vtec6000 and he sourced me a engine through cda.
    The engine we decided on was a b18 off a sir integea( low compression) but use my head minus the high compression parts(head gasket, cams etc) and replace them with oem type r parts so we ended up with
    A b18 sir engine with type r head for low compression with really good air flow, that was grand next on the list was a turbo set up and just as I started to look, one pops up for sale,
    A hks b18 turbo kit with braided lines the works, a greddy fmic and a t25 turbo but with such a rev happy engine decided to go with a t28 turbo aswell as that I picked up fuel pump.
    Now after the engine getting the work done on the head etc I needed to put a bit of milage on it before we turboed it so I got the car back on Saturday and went for a nice long drive I've 350 miles on it a the moment and the car is getting sent back to cda tomorrow to get the kit put on and mapped on Thursday hopefully, at the moment it's going to be mapped on 330 injectors so about 260ish bhp but hopefully get injectors, boost controller, external waste gate and gauges and go back for a remap and see 290ish bhp and leave it there for the time being,
    I'll keep you guys updated :thumbright:
    May 2011
    Default June 23rd
    Just got the car back, it's crazy not sure on the bhp yet as it has to get more mapping, but it's mad, it's boost creeping ATM due to the actuator we think so I'm just talking it handy, its so responsive and smooth,
    Big thanks to vtec6000 he spent so long on mapping and getting it right, pure gent
    And also to the lads in cda that built the engine, great work and very helpful
    here some pics
    di Member rico180's Avatar
    Feb 2011
    Formally westmeath,currently calgary, Alberta .
    not a big fan of civic's . but thats fair work you put into that civic. nice power too before it went BANG!!!!!!!
    May 2011
    Nice one man, it's running about 245bhp with 210flbt now hope to get it up to 290/300 in the next few weeks
    Jesus man fairplay but its a drifting forum like and your going to get fair abuse from some tryhards on the forum.
    Nice Civic.
    Looking good dude
