Two tone would be cool but a red ps on miesters is a mouth watering!
Dunno how nobody has spotted the camper in the ome of the pictures jimmy! :P
keeewl, i second two tone man.. looks soo good.
was this car left lyin in coolaney for a while???
long time no update
So was on the lookout for a TD06 or similar after availability / Prices scared me off this came up
arrived nicely snug fitted on a pallet
This came out of a ps13 from Japan suspected melted piston (blowing oil out the dipstick),Wont know for sure until I strip it
Schhhpec
Power Enterprise / IHI pe1420 Turbo
braided oil and coolant lines
4 branch & Downpipe
Tomei pon cams 2525lb is stamped on them
nismo 550cc injectors
s15 pistons
Got the ECU to go with it aswel (revs out to 9200) but will probably go nistune / power fc to be safe
So will either replace the fucked piston or swap the bittom end depending if a ring broke up and scored the cylinder or not either way should be a healthy responsive engine Basically the same set up as Risky devil 180sx
http://www.180sx.co.uk/community/ped...y-devil-180sx/
Also have
Orc 409 series clutch
Nismo 2 way GT pro LSD
Cusco adjustable anti roll bars
nice medium sized Greedy fmic
Jimmy dont change the ecu mate its awesome whatever the wee japs did with it! Ran 360+ bhp, and hits like Mike Tyson back in the day, I'd at least run it with that ecu.............. ya mite like it. Good to see it arrived safely :-), if ya are going pfc or nistune keep that ecu and put nistune into another standard brain, will be hard to get a map as good.
Cheers lad yea wel I will run it on that first to see what its like and get martin Tracey to put it on the rollers and see if shes running lean or wat ..
Stewart gilmour incar nutts corner, drifting - YouTube sounds well in this vid
