Have a brand new set of these. Will fit s14, s15 and r33.
Rear camber arms with pillowball ends allow you to accurately set your rear camber -A must for any lowered car as the standard eccentric bolt doesn't allow enough adjustment.
Correct alignment is essential when trying to achieve the perfect drift setup.
Pillowball bearings replace the rubber bush in the standard arm and remove all unwanted movement in the joint.
Should be worth 70 euro..
Link to pic:
http://tinypic.com/r/inbvi0/6
