Results 1 to 9 of 9
    Default bmw dirty diesel e36 engine convo question
    if i have a 318tds saloon, would the 325 tds be a straight plug and play job?
    is the 525 and 325 tds engine the same?
    do i need anything more than engine / box? like ecu, prop, shafts, loom ect?
    would the 318tds box be up to the task of the extra torque..
    goin from 4 pot to the 6 would there be any extra stuff required, brake upgrade ect.
    rob
    Administrator
    Going from a 4cyl to 6 cyl id guess you'll defo need ecu loom box and prop as a bare minimum anyways?
    Would you sell the 318tds engine?
    Cork
    Need engine, box (if possible but not absolutely essential), prop-shaft, gear linkages, loom, ECU&EWS, rad, inter-cooler, exhaust
    If using an E34 engine, bare engine is physically the same but you need everything else above from E36 and you need E36 sump and engine mounts too.
    I reckon brakes are the same on both 18 and 325tds but you'll need 325tds front springs.
    cheers for replies lads.
    do you do them conversions dave?
    Cork
    Yeah, haven't done any 318 to 325tds swaps yet but they'd be alittle easier than others in fairness that I've tackled
    Was going to out a M51 into my E30 Touring but think I'll hold out for an N47 or maybe even an N57
    nice one, would love a 325i but petrol prices are a joke, and work might be movin so might be usin car for commute instead of motorbike
    pm on way
    di Member WayneR33's Avatar
    Jan 2012
    Kildare
    Very easy to get a bit of power out of the 2.5 tds aswel, have an e34 myself bet out the cat, turned up the boost and got a chip off of these lads endtuning.com for €100 its alot smoother, loads of torque and spooles up way earlier
    Cork
    yep, cut the cats and a chip can have you at 170-180bhp no bothe and 330-350Nm
