Any body on here know there way round a cosworth engine. My problem is when the car is idiling it only runs on three cylinders and as soon as I put my foot on the throttle pedal it disappears,![]()
sounds like a weak injector
[Signature removed by Admin]
Which cylinder is giving you trouble,
Pull off the lead cylinder by cylinder and find out if the engine note changes for each cylinder.
That will get you to which cylinder. you could try swapping injectors to see if problem moves cylinder with injector, and/or check impedance of injectors to ensure they have not shorted or damaged.
Let us know how the outcome.
Cheers, number 1 for definate. I will check for leaks. How do I test the impedance?
unplug the connector off the injector and using a voltmeter (ohmmeter) when changed to ohms place the two probes to the two spades of the injector. I belive it should read 13-17 ohms but you can cross check with the other injectors that are working correctly
Just checked the injectors with an ohmmeter:
no 1 = 4.54 ohms
no 2 = 4.55 ohms
no 3 = 4.56 ohms
no 4 = 4.52 ohms
have ordered another injector and seals to try and cure this
