Had a quick search for boost problems but can't find anything similar to my situation.
Was driving home from work and put the foot down for a bit in third gear boosted fine drove along grand dropped someone off not turning off the car then drove home but was getting no boost at all nothing, it would not go above 0 at all in any gear any revs.
now i've checked around for leaks but can't see anything off hand. I had a problem where the actuator bar came off the connection before so checked that again and it still attached. I had leaks before but still managed to get some boost but took a while to build.
My batterys on the way out so the cars had some rough starts lately jumps, taking a few turns etc to get it going. I'm kinda paranoid that its the turbo gone even when you turn off the car its like you can't hear it spinning where you used to be able to before. This whole 0 Boost is puzziling me could it be because the turbos not spinning or could it be another problem with the wastgate just internally instead of the problem i had before?
