Results 1 to 10 of 12
    Flat Out! Eoin R.'s Avatar
    Tipp
    Default RB25 breakin down at 5000rpm
    changed the coilpacks,changed the ignitor checked the fuel pump and earths!!
    Any ideas???
    loves cookies
    In the clouds
    breaking down as in? engine stalls? car wont go forward or what?
    Cork
    What boost are you running, what spark pugs are you using + what are they gapped to ?
    Did ya check ALL boost pipes eoin?
    Check intercooler pipes, vacume lines, and assuming boost is normal and everything else you've said is fine then possibly the afm on its way out..
    as per nissandoctor above,also in relation to cooldrft above last rb i worked on had similarish symptoms turned out the spark plug gaps were too large brought them down quite small about .8mm i think cured the problem,that car was boosting approx 11psi iirc
    Tipp
    Sound out lads ill try the above 2mro and let ye know!!
