Results 1 to 10 of 20
    Default help please ...for the sr20 heads
    ok i know its a long shot but ive tried everything, pretty much since ive built my car its had a problem that pops up every so often.....it will run perfect and drive perfect and has been mapped twice without problem on the dyno but when its drifting under load up in high revs it starts to break down and splutter and if i clutch it it comes right after a few secs like its flooded, now ive changed coilpacks, pump, checked boost leaks,pump wiring, strange thing is it ran perfect all weekend in punchestown but last weekend it ran worse it ever did even cutting out mid drift and ii didnt touch the car since punch has anyone ever had anything like this happen any input would be greatly appreciated
    di Member JDMep82's Avatar
    Jan 2011
    Check lambda sensor?
    Edit* just said I'd suggest that cause a friends 180 was givin similar problems, come off the throttle then go back on heavy and was spluttering and hesitating and similar to yourself, turned out to be a faulty lambda I think
    Member jay SR's Avatar
    Jan 2012
    cork
    did you check to see if pressure is building up in the tank ?the tank might not be vented enough!
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by joey banana s14 View Post
    Drop it into me and i will take a look at it.
    Robbie
    di Member 1jsoarer's Avatar
    Im no SR head but check your vacuum pipes going to the fuel reg joey. they need a decent vacuum. maybe you have a dump valve or something T'd into the line??........just an idea sweet cakes
    Signature removed
    cork
    ill take a stab at it losing fuel pressure,needing a surge pot
    easy to test
    you got a swirl pot?
    that could be your problem....?
    thanks alot lads no swirl pot standard tank with walbro...ill check these things out
    Feck the walbro away and get a gtr pump either way joey, ive a s14 lambda sensor, ignitor, coilpack loom there you can try anytime bud
    Apr 2012
    Dublin
    Wink
    Check all major power cables are in good nick and the terminals on to which they go I had a ae86 with a mystery cut out problem for about six months could never figure it out then 1 day driving out of the estate it died just everything gone after about 4 hours we found the problem the main positive battery cable going to the starter was on tight but the terminal itself was loose inside the starter an it was earthing on it's self...... I know that is more then like a once of problem but Ye never no!!!
