In Cork full time man, driving this daily too so its around all the time![]()
long over due update!
NCT'd once again. all i needed was a caliper on the back
NCT SPEC!!
Then i got bigger tyres for the front, rubs on full lock but its grand! ill get over that.
Then i noticed an issue with my AFRs. on ful boost they were all over the place and on warmup. well pretty much everywhere,
has a look and saw i was missing some bolts on the turbo
on closer inspection
two sheared studs.
Then Nicolas came to the rescue with a spare flange
the bolts here are M10 for extra stregth. just had to redrill the turbo and fit a new gasket.
Job done
after i remapped it again its running sweet. i also fitted an EBC and just making adjustment so so i can run 1 Bar.
nothing else to report!
ha just saw your thread on here nowmust show Denis...
btw, still looking into the wheels, didnt forget![]()
Thanks Conny!
Men.
Turbo is on. Its goes like this
2000rpm .... No boost
3000rpm... No boost
4000rpm... Whats that slight whooshing sound?
5000rpm.... Brraaaaaaaaa
Holy f**king shit where did that telegraph pole come from!!
Needs tuning though. I got some det up high closer to 190kpa so i loaded some fuel on that shiz till i can get on my mates dyno.
Think i kinda prefer the t25. This will do for now but i might rebuild the t25 and put it back on. I might gain some rpm off the threshold my pulling timing from the cells around where it start to spool initially and add some fuel. Might also try taking away some fuel. Theres arguments for both
Thlughts?
update!! It's been a while
So i had a few problems with the car a while back.. the return line for the turbo shat itself, and the engine then in turn...shat itself..
This little beast had me going for a while but the lack of power and open diff hurt...i even got checked for aids after i drove it the first time...
so i pulled the engine out of another car (not the aforementioned car)
who said you cant tow with them?
i cleaned up the engine
Then the car sat idle for a while.. i bought a lovely van and lifestyled pretty much all the time in that for a while...
said van
Then one day i got upset and got some insurance to cheer me up
behold
the only major update really was the injectors
make no mistake, this car is not clean, and i do not take care of it.. the bodywork is really shit, but the mechanics are fairly solid... thats all i want from it
also
Thanks for reading see you in 2 more years...
