Results 21 to 30 of 43
    Dec 2011
    Mayo
    Default 1J - ps13 road car build.
    Starting this again couldnt get pics to upload on the last attempt!!
    Bought this silvia back in october 2011 private sale and wasnt sure what the plan was, knew i wanted a ps for a long time, 92 regd ps13, 75klms, nct'd , sr20de and drove home without a rattle
    Parked it in the shed straight away and it remained there for about 5 months and the build began.
    First thoughts were to keep it sr and fit a turbo engine, general restoation, respray etc, then changed my mind and wanted to go RB25, finally i saw sense and decided to go all out and do a 1jz conversion, first thing i required was a donor car.
    Here it is, luckily ran n to a JZZ30 manual soarer.
    And this under the bonnet with an R-154 box
    yes it is a single turbo conversion also.
    With the two cars in the shed i began ripping both engines out and when this was done the silvia was in for a major stripping.
    1JZ engine coming out.
    Bought a few bits and pieces in between this work being done
    6 puk clutch, 2 brides and rails, stamped TOMEI 2way, twin box headlamps, tein's, walbro pump, new japspeed arms and polybush kit - coming along..
    Meanwhile was very busy working on the silvia, stripping out the engine bay of every nut and screw for a fresh coat of paint, removed the battery tray from the bay, under sealed the underbody, sand blasted my subframes and had them painted, fitted the poly bushes, arms, 2way etc .
    Also i striped down the engine and with high temp resistant paint done the block and steam cleaned the head etc etc.. a new t/b kit nd water pump, 6 iridium plugs and filters were purchased aswell. went a bit mad and kinda polished the gearbox
    After paint, i assembled every thing from the petrol tank forward, fitted a full s14a subframe/ w bones/ rack/ new ends/ 5 stud hubs s14 also and skyline gtst spec2 brakes all round, using the R33 rear hubs (small bit of messing with the Hi-Cas but sorted this with a press) fitted the coilovers, bleed the brakes and it was rolling again and ready for the off to be 1j'd..!!
    Got a brand new FMIC, alloy rad and full stainless exh system in to the mix!
