Results 1 to 7 of 7
    Jan 2012
    Default vacuums help needed
    no matter what way i try em the car wount run right .... and any tell me where the vacuums go on a s14 sr20 vvt engine .... its the 1s at the inlet mani that ar given me all the bother
    cork
    im not exactly sure what your issue is?
    is it connecting the feeds around the throttle body or what
    Jan 2012
    these vacuums i cant find where they go and 2 have a lot off sucktion when the car is runnin so i cant block them off or the car cuts out on me
    there 3 vacumms there
    the 1 that has the pipe on it
    the 1 wihout a pipe on it
    and at the top there is another small 1
    1 is caped
    cork
    of the 2 together....
    one goes to the fuel pressure reg
    one to the carbon thing,so cap that
    dont know the other one if i cant see it.have you a dump valve?
    Jan 2012
    cant cap them dude its real weard there both drawing in a lot of air when the car is running and car just cuts out with them caped
    cork
    but theyre vacuum lines.they should draw in air if open.where have you fed the fuel pressure reg from?
    have you a boost gauge fed from somewhere?
    is your idle control valve working properly?
    take a few more pics if you can
    di Member jap scrap's Avatar
    You can just blank them 2 pipes they go to a filter for co2 emmisions its not needed
