hey there ive recently installed s13 subframe and adj. front tension rods (have r33 front LCA's) now im thinking its time for a wheel alignment basically i want to know what would be a good spec for front and rear for a drift setup
you got any adjustiable arms? Front & rear camber arms would be a big help on the r32..
Wez @ WKD Imports does top notch Alignment & can also supply you with Driftworks adjustable arms at very good prices!!
He did all the suspension work on my R32 and made it a total different car to drive.
no i dont have any aftermarket arms :/ only r33 front lcas and adj. front tension rods
Any idea how to set up alignment
Take it to Wez at WKD imports he can advise you on settings and do the alignment.
If he is too far away take it to a reputable tyre depot with a computerised 4 wheel alignment equipment
Rough settings would be
Front
Camber
-2.50
Toe
-0.10
Rear
Camber
-1.00
Toe
-1.00
This is roughly what I would set your car to but it all depends on your cars power, lock, setup and drifting experience, as you can tweak each settings to suit
What about castor and i read in a lot of articules that rear axel should have a small toe out
Toe out will decease grip toe in will increase grip on the rear.
Castor I would set around 7.60
Castor effects your steering return . Ie when you let go of the wheel, how quickly it returns to centre
