Done a few of them, can keep or loose hicas pump, rack is a straight fit just use your own tie and track rods, have lines and pump if ye need em, if your using non hicas pump best to change crank pulley, gimme a bell if your stuck
did you take the vanes out of the back of the pump and just bolt it back up or did you split a SR pump and stick the back of it onto the hicas pump?
your really best off changing the pump!! iv been down that road, its trouble just waiting to happen...! Its also a better job without all the shite of the hicas pump, better off with the non hicas pump!
No really need to change the crank pully, a 3 rip belt will be grand on it, iv had no issues yet & ask anybody that knows my car, iv had awful trouble with the steering for a while! its eventually sorted now..
