Results 1 to 10 of 13
    Default 180sx - Ready for Track Questions..
    The last time I drove the 180sx was almost a year ago...
    It sits at the side of the house and the battery always drains.. Started the odd time every few months. Ticking over then turned off.
    Before I had it out last I changed the oil, oil filter, plugs, and coolant.
    -Mobil 1 15/50w
    -BCR8ES
    -Orange antifreeze
    -k11 filter
    When I had it out the decat gaskets were blown to bits and the car was running standard boost - reading 0.4 odd on the cheapo boost gauge...
    I was driving it like a vtec, inc the back straights and didn't realise that near the end of the day one of the rad pipes became a little loose.. The thermostat was jumping to the top in no time... that was the last time the car was used.. A year ago...
    Now that I'm half ready to pour money into getting it out again I have a few questions....
    Should I do the whole service again?
    Does oil deteriorate?
    what about plugs? Swap them anyways?
    The gear stick feels like a tooth pick as oppose to a fluid 'volkswagen' type shift... Should I just top it up with oil? What oil, and where do I buy it?
    Someone mentioned 75-90w GL4?
    In retard terms, what else should I be wary of or even the basics of what to look out for/do when a car has been sitting?
    If anyone could tackle a few of these questions it would be great.
    Thanks,
    Tom.
    Spark plugs be alright, Id change the oil again tom before you head out. Check you have enough coolant (not water) mixture in your coolent ssytem.. the more coolant the better, was water rots/eats away at aluminium so you can never have enough coolant in your mixture!
    check the tyre pressures oil and water level and drive the balls outta the yoke!!
    Quote Originally Posted by gem-s13 View Post
    lol, much better advice than mine!!
    think i heard you didnt change feck all oil in your car last year? or that not true?
    I have a full bottle of the antifreeze. Chuck loads of it in then? Cause the scummy rusty coloured shite it coming about it.
    If there is anything I do, it would be the above. No tacho, plus standard boost = Driving the fuck out of it like a vtec that couldnt pull shite, with the left foot stampin' the fuck out of third.
    Before Mondello I want a downpipe, and possibly a rad.
    Then what should I do for boost?...
    i only ever run water, cars kept inside all year around so i never use anti freeze, change oil filters alot but havent changed the oil in over a year just top it up whan the filter is done
    Junior member Foxy's Avatar
    May 2010
    Hell
    haha Brilliant
    Thanks lads! I really want to get out on the 9th now.. Working flat to try get money together. Its getting there thats the problem.
    Quote Originally Posted by serious tom View Post
    tom, get it out!!!!!!
    Il be there, well 99% sure i will be! lol
    di Member thegosson's Avatar
    Arrow
    i recon it should be fine to go, leave her run for a good while get it good and hot (woking tempreature) for as long as you can at home. And especially before hitting the track.
    im assuming you haven't already changed the gear oil in it before...... use redline MT90 works very well with nissan syncros and good for the kind of abuse your planning on giving it. the only place i know that sells it is (COUTURE-AUTO) dunboyne, co.meath. they always have it in stock on the shelf. but heres there number just incase you want to ring first 018253949.or driftworks do it also.
    the plugs should be fine but ts always a good plan to bring a spare set any time your going to the track, just incase. pitty to waste a days seat time and money over a set of plugs. use NGK Iridium BKR7EIX plugs for standard-mild tuned engine unless the car was mapped to a different heat range ie. much higher power than standard. these can be got at any good motor factors but may need to be orderd so dont leave it too late. Drift works also do these plugs.
    engine oil you get what you pay for really, a lot of people say oil is oil, thats grand for a normal tip around town car, but with the abuse these cars are expected to put up with, it needs to be right. Mobil1 is your man. cant remember off me head but i use the Mobil1 superS and never had a problem. for example iv a mate who used to work for garrett turbos, rebuilding them and he aid he could spot a turbo straight off that had been run with Mobil1 oil, clean as the day they were fitted. so thats enough for me to use it.
    you will run into power steering fluid over heating and blowing out of the resivoir, this is easily fixed by adding a power steering fluid cooler also found at driftworks, cheap as chips and you'll never have to go near it again.
    if youve a standard rad, make sure you still have the plastic fan shroud couling thingy on it or else your fan is at nothing, may aswell not have a fan on it at all if its gone. uprate the rad cap to a 1.3 Bar cap too,this will increse the cooling system pressure up to 1.3 bar and by doing so you increase the coolants boiling point. for example boil some water and at 100 degrees it starts to evaporate. pressurise the water and boil it and it could go to 120 or so degrees before it starts to evaporate. (hope you get what im saying). Oh and use coolant in the coolant system not water. only use water to get you out of a sticky spot.
    hope this is of help because it took me feckin ages to write.
    oh and i see the code you have for your plugs looks like there heat range 8, normal is 7 for lightly tuned engines. was it mapped to a heat range 8 plug or whats the story there?
