Results 1 to 7 of 7
    Default audi a4 antenna?
    wel lads just got a a4 and the radio is not working but the cd player is so i think the antenna is loose or cracked but cant find it does any1 no where is the antenna is in the car its 03
    thanks
    Built into the rear glass if I remember right!
    tats wat i was afraid of any way of fixing it
    Theres a tube of gunk made by Granville to fix it,Its about 30quid retail!
    Quote Originally Posted by dan View Post
    Pull out the radio and make sure its plugged into the back
    cork
    im not 100% sure but,
    doesnt the unit get its earth from the antenna?
    so it would need the antenna connected for the cd player to work,
    and if it was even a poor connection it would still have a signal for the radio,even if it was a shite signal?
    i know that from some older ones ive had,but not sure on audi radios
    di Member pepsterx's Avatar
    Mayo
    Mick is right it is in the rear windscreen, i got a small unit that you stick inside behind your rear view mirror and run the wires down trough the A-pillar, alot better reception then original antenna, alternatively if you have windscreen cover pop the window and claim
