Results 1 to 10 of 11
Thread: RB25 into R32
    Default RB25 into R32
    I know this has been asked probably a thousand times I've been researching for last few hours and have found some conflicting instructions from what I've read
    We have a full r33 spec 1 car so going to use the loom and ecu out of that
    From what I've read we need to use power steering and alternator off 32 and that part of the loom , use the 33 wipers and loom , and there is some chopping and changing involved in the interior loom now is it actually as simple as that?? If I just get the wiring diagrams for both interior harnesses and chop and change should this work or am I being far too green?
    Also use 32 or 33 mounts? must modify box mounts and get prop modified other than that any info would be greatly appreciated or any links thanks!
    di Member nicky h's Avatar
    dungarvan co waterford
    Not sure about wireing but you use the rb25 alternator and p/s pump and rb20 engine mounts
    Quote Originally Posted by nickae86 View Post
    Cheers, could'nt understand why the write ups I was looking at said to use the rb20 alternator and ps pump!
    Dec 2010
    get onto walton on fb lad or else ring him tell u exactly wat you need to know
    MEATH
    If it still has hicas then the rb20 p/s pump will have to be kept, handier to use the rb20 alternator is all
    Sound, will try him hes hard to get at times tho!
    must look into that! presume it does!
    MEATH
    Quote Originally Posted by dannyc View Post
    Well if it don't you could use the rb25 p/s lines and p/s pump , if your using the hicas pump there's a crank pulley issue cause of belt, just a rib in difference , nothing major
    Hopefully the hicas is gone anyway make it handier still trawling through wiring diagrams looking for the interior loom pinouts
    Ennis
    I'm in the process of.fitting a spec 2 rb25 to my r32
    Havent gone at interior wiring yet.
    Had to use r32 gearbox loom, r33 knock sensor loom, rb20 p/s pump, rb20 starter.
    Will worry about wiring wipers at a later date
    www.stickybusiness.ie
    Vehicle Graphics & Signwriting
