Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Turbo ques??
  1. #11
    Greystones, Wicklow
    If its a boost leak it wont boost feck all really, have you a boost gauge??
    Should get dark smoke if its boost related..
    And does it only splutter sometimes on boost?
  2. #12
    Its very hard to give a defo answer when your not looking at the prob in person.
    But i'd go with Jay.
    check the water for the rainbow effect, Or the oil on the dipstick should give it away.
    but the comp test is your best bet.
  3. #13
    di Member Scamper's Avatar
    Update:
    Got the compression test done today and she read 155psi in all cylinders, im delighted, also got the engine fully checked and mechanic said its perfect, so we went at the turbo and low and behold i was right, there was play in it, its wanked!
    Glad i know wats wrong now, so i can get it sorted, thanks for all the help lads!
  4. #14
    Greystones, Wicklow
    Good stuff, glad you figured it out!
    Just wondering though as you had said alot of white smoke, did the mechanic give any explaination for that?
