Results 1 to 10 of 14
Thread: Turbo ques??
    di Member Scamper's Avatar
    Exclamation Turbo ques??
    Rite basically i have a strong feeling my turbo is on the way out
    - my car is spewing alot of white smoke and it is getting progressivly worse
    - My car sometimes stutters in boost
    - But car is idleing and running fine bar this
    I have no problem changing the turbo, im gonna be going with a t28
    Wat im asking is, is this def my turbo seals that is the problem, and could it be anything else, most people i have talked to said they are 99% sure its the turbo, but jus want yer opinions!
    Thanks in advance lads
    Scamper
    i dont think its turbo issue's,i reakon it a miss or fueling
    Anyone else?
    Quote Originally Posted by Scamper View Post
    Anyone else?
    White smoke sounds like turbo alrite lad
    white smoke could be turbo or head gasket
    Greystones, Wicklow
    Is it just at idle or low revs, or most of the time??
    White smoke generally means water/coolant leak, i.e headgasket!
    I'd do a compression test on all cylinders and see if any are down on pressure a wee bit!
    If you think its the turbo oil seals then the smoke should be blue or greyish in colour..
    white smoke sounds like a HG to me too.
    you can usually get a little blue smoke on idle when the tubby seals are going.
    what condition are you plugs and coil packs?
    did both problems start at the same time?
    you can get a test done on your coolant to see if theres any trace of oil mixing in with it
    di Member thegosson's Avatar
    Quote Originally Posted by Jay View Post
    what jay says here would be what id say too.
