have an sr20de engine in but has no spark in the plugs , no ignition lights coming on and no curent going to the fuel pump.
will a 200sx s13 english ecu work with my set up as the plug is the same.
thanks
thanks
give more info, did you install the de engine yourself? what loom and ecu was used?
is it cranking over?
no, a 200sx english ecu is for a ca18det, it requires too much modification to work.
check all your wiring and fuses to start
yes installed myself. dont seem to be any fuse blown. its turning over fine .
why wont the 200sx ecu work
thanks for the info
what modification work needs to be done. i have the ecu that came with the engine in it but dont think its working as i have a spare 200sx 1 there
I have an S14 SR20DE ECU for sale if it's any use to you? €30
thanks lad but got sorted, turned out to be a faulty kill switch![]()
